F337GP AD info
Rick,
I have reviewed the ATP package and this is what I found:
ATP's index of applicable AD's for the "Reims Pres SkyMstr F337GP" lists:
#76-04-03 Preclude Restrictions of Control...
Internally AD includes F337GP
FP3370001 thru FP3370015
#87-20-03 R2 Assure proper engagement of seat locking...
Internally AD does not specifically list F337GP,
but lists FP337 - All, Also Lists F337G All
This AD applies to seat locking mechanisms and
seems to apply to nearly all Small Cessna Aircraft
97-01-13 Prevent Fuel, Oil or Hydraulic Systems Failure...
Does list FT337GP - Also seems to apply to nearly
all small Cessna aircraft
2000-06-01 Prevent Foreign Material from entering...
Does list F337G and FT337GP
Relates to length of standpipe in fuel strainer
Kevin has posted text from all the 337 Airframe AD's on the site in a Zip file. You may want to download that and review the info yourself. I'm sorry I can't decode all of this for you, but I have no idea how these models break down. Also, I don't know if AD's for aircraft that are used as the base for a modified model apply to the modified model. It could be that in order to get the modified designation the AD's of the basic model have to be complied with. The only exception to that is the recurring one (87-20-03 R2). Reims could have done a complete revision of the seat rails. I'd suggest that you talk to your (most) local FSDO and Reims.
Good luck... I'm sorry I can't offer more.
Jim
