Thanks for your answer !
Yes, I would be interested in some photos, especially the end of the boots and the negative leading edge camber areas.
Take your time, no emergency !
Do you know if the boots are same size then original P337 ones ?
Could you also mesure the boots dimensions for me, please, including the horizontal stabilizer boot ? I will compare with the original ones.
About certification, do you know if the boots are part of the field certification or are they parts of the R/STOL STC ?
If your Riley is a Super Skyrocket, the useful load is rather low : does it have a gross weight increase to 5120 lbs ?
Thanks for your answers
