Unread 12-09-06, 09:37 PM
The problem I'm having is the valve sweats. I tried to tighten the screws on top but it's almost impossible because my hands are too big to get around the fuel lines. It seems like there should be an access panel on top of the wing, but of course there's not, and it's a structual panel.
I found a small screwdriver at Sears, it's only a 1/2" tall, but the handle is a very round wheel that I can use with just my fingers. I'll try that.
But if I have to remove the valve from the wing (to replace the cork seal) do you have any tips/tricks to pull it out?
