VAR crank issue doesn’t apply unless the case halves are opened.
The way I read it, basically same rules apply to the RR engines as domestic continentals.
Also interesting sentence “accepted for use on US type certificated airplanes”.
Question would be if you can twist that into FAA acknowledgment of treatment of them same as others gets you over the hump. And transfer that over to CAA. How about a call to AOPA legal services?
