74 model, had to send a few parts back, number 3 riser did not fit to the collector correctly, I would say loosen everything up, attach the ball joints and go from there. Make sure the rubber mounts are not worn out.
This would include loosening the bolts on the turbo to the main turbo bracket, there is some play there. All parts including tailpipe need to be on and loose.
Dan
