Unread 06-15-21, 11:00 PM
The Invert-Pak is out on my airplane; all three EI panels went out simultaneously, so following the maintenance manual, the shop is replacing the "Pak." I have part #71254-6 in hand to replace it but cannot find the inverter up under the panel.
With your EI panel out, Rick, would you see if you can locate it?
