Unread 07-16-21, 10:00 AM
cessnadriver's Avatar
left magneto timing tips, tools, or tricks?
TO DavidC
Hello, welcome to the Skymaster world!
To review, the left mag as looking from the accessory side (rear of the engine).?
IF the 336 is laid out like the 337, I found that a 1/2" racketing box end will JUST fit. To start the nut, if removed, I found a 1/4" flex drive bend 90 degrees with a 12" 1/4" solid extension works best! Also I tape the nut in the socket so it doesn't fallout. On the right mag I found that a 1/2" box end wrench that I heated and bend into a crescent shape works well. FYI you'll only turn the nut about 1/6th at a time. Hope this helps!
Regards, BILLS
