I've come to the conclusion that the unknown item in my W&B is the weight of the entire turbo system, which was installed after my airplane was weighed at the factory.
If the 2968 lbs is correct, that is a VERY light plane. I still can't figure out where I'm "fat" - the turbo is about 150 lbs, and that G is lighter than my plane minus the turbo. The 3068 lb G seems more likely.
My empty weight is 3,174 lbs.
1969 T337E
