Thread: Wing root seals
Unread 09-12-21, 10:38 AM
cessnadriver's Avatar
Wing root seals
Yankee Clipper.
FYI. The other member suggested Aircraft Spruce, the one with the tail would be best, if you're not going to install, or can't find the original Cessna seal? The seal is only the there to keep chafing down and to close the gap between the the wing and fuselage? Hope this helps.
Regards, BILLS
