Unread 10-19-21, 07:28 PM
Have a good visual look at the fuel line to the nozzle and see if it has a hole or crack - it could have been rubbing on cylinder fin. I know I have replaced 3 due to this (prior to leaking or failing). nozzle could be clogged? Can you check your engine monitor data from last flight and see what #3 cylinder was doing?
