Unread 10-27-21, 07:21 PM
JeffAxel JeffAxel is offline
Aero Air is a good shop, but they mostly work on turbine equipment. Northwest Aircraft Maintenance, also at HIO took care of my P337G for the three years that I had it. Rian and Dirk are good honest folks. Either shop would be a good choice, Aero Air probably has a better way to pressurize the plane on the ground, Northwest Aircraft Maintenance will likely be a less expensive option. Your problem likely is just due to cabin leaks, which can take a bit to track down. The more you find and fix, the higher pressurization differential you can achieve, the more leaks you find! Be sure you get it to where it will maintain 3.35psi on one engine and you will be where you need to be. Lots of places that airframe can leak too......
