Does everything work normally up in the air? I did swing check with drill and seemed drill doesn’t result in pump output like with the engine running it. However didn’t have to hold the gear lever. Wonder if there may be some weakness in system overcome with engine operation/higher output. Like leaking o rings in hydraulic pack. Or some weakness of the pump. Might be worth a call to Cox airparts.
