Unread 12-14-21, 07:26 PM
Jhogan0101's Avatar
Problem solved:
Rear intake/return fitting on rear pump was loose. The nut holding the o ring was not tight. The pump was sucking in air and mixing it with hydraulic fluid. We replaced the o ring and resealed. Crisis averted.
https://youtube.com/shorts/VsAM1Hqdw9Y?feature=share
337B
Philadelphia PA
