Unread 06-03-22, 09:21 AM
SteveG's Avatar
SteveG SteveG is offline
The position of the master switch should have no bearing on whether the engine runs or not. Or did you mean that you are turning the ignition switch off to stop the engine? If the master switch kills the engine ignition you have a second problem to solve as well as the fuel cut-off issue.
