FULL Avydine
Hello,
Thanks for your replay. I really thank you for you help.
You ll find attached a pic of the actual panel
My questions for you
TRANSPONDER 340
Can you see the trafic on your I pad on forflight or skydemon ?
As I have a Garmin 430 I would like to add a IFD 550. Can I then eliminate the vacum pump ?
I have An autopilote STEC 55 x , can I use it with avydine product ?
Concerning the engines monitor, With you shadin , do you have gaz gauges also ? Did you keep the old gauges ?
I would like an Angle of attack instrument , do you know if the IFD 550 has this option ?
Any other advises ?
Alain
