Gear Doors
JWSMITH
I have a 1967 337B, but I am not sure how to solve your problem, let me think about it a little longer.
BTW you need to mount a mirror under your left wing so you can see the gear doors from the pilot seat. I put mine on about 3 years ago. I can also see the rear prop(after I painted the prop tips on the front side). If you need help building a mirror holder, let me know, I made mine (no extra holes in the plane). The other day after I finished the annual I took it for a test flight, when I went "gear up" the yellow light kept blinking, I looked at my mirror and I could see the rear gear doors were not up, not to take any changes I put the gear down an landed. After I went over everything "again" I took it back up and it worked fine.
Fred N358
