Unread 12-25-02, 12:31 PM
rear prop
Paul
Two years ago I replaced the rear engine and a rear prop. On the test flight a bolt flew out of the undercarriage and hit the prop. Total time on new prop : 22 minutes ! Total damage - major.
Murphy says anything in front of the prop will end up in the rear prop. It has an affinity for such matter.
On a new prop you have about 2 inches on the tips and around 3/4 of an inch on the leading edge. There are specific limits. If it is on the face there is more of a problem.
You need to send it to a prop shop for inspection and possible overhaul. They will tell you if new blades are needed. Based on the price of the blades it is almost better to get a new prop rather than old. You have additional cost of putting it altogther again.
Check riley and see if Mary-ann has one that came off an upgrade. They usually have some kicking around.
Word of warning to new pilots. Make sure you do not do a runup on icy surface as the rear prop can ingest ice and it can do considerable damage....
I have reduced FOD by running up the rear engine and at about 30 mph bringing in the front engine assuming the runway is sufficient. I have found far less damage to the rear prop using this approach. I also taxi with mostly the rear engine.
merry xmas to all.
