doesn't make any difference, if you have an engine monitor, you can do a GAMI lean test to see how wide your fuel flow spread is between first to peak and last to peak. If you get a lot of rough running or the spread is greater than 0.3gph, you will likely need GAMInjectors. The plane likely will not run quite a smooth as ROP, but it will use less fuel. Less of a benefit in NA engines than turbocharged.
