Thread: Need a name/PN
Unread 07-06-23, 12:27 PM
The part number is S2130-1 and is the rubber seal that is glued into the channel that runs around the perimeter of the avionics bay access doors. Textron has over seven hundred feet in stock.
I replaced them on my plane about two years ago. At the same time, I replaced some of the capped camlock receptacles that had rusted holes in the bottom that had been allowing water to drip into the avionics bay behind the instrument panel. Problem solved.
N337K-FT337GP
KLOU
