Unread 07-26-23, 09:10 PM
cessnadriver's Avatar
Smile removing front alternator
TO Joes.
Thanks for the reply for removing the alternator!
Here's what I found while remove the alternator. I took a 1/2" BOX END WRENCH ground 1/2" notch in the end to allow it to be used like an open end wrench but with the ability to make small turns of the nut that an open end wrench won't allow. Does that make any sense? FYI-It took almost as long to remove the terminal connections (45 minutes) VS removing the mounting nuts (1hour)!
Thanks again, Regards.
BILLS
Owner/pilot/A&P '65 C337
