Unread 10-10-23, 11:46 PM
If you are only servicing with nitrogen or air I have done this without a jack. I would connect the nitrogen bottle and stet the regulator to @ 30 psi then pull down on the booms till the strut was full extended. When the weight was put back on the nose gear, you can see if you need a little more or not if you don’t have enough extension add a few psi and do it again.
