Originally Posted by SteveG
This sounds like you're considering jacking the nose wheel off the ground using only a front jack. IMHO that's a poor idea. The front jack point is primarily used to stabilize the aircraft while supported by wing jacks. Lifting the nose without tail boom stands risks dumping the aircraft over backwards. Take care.
This is why its really a two-man operation to safely lift the nose. If you do it alone, try to find something to support the tail or you could be buying new lower tail cones
I'm just throwing ideas - old tires stacked up, a rolling toolbox/bench covered with cardboard or towels, the open gate of a pick up truck. A tail stand would be ideal, but finding one tall enough for the 337 can be a challenge.
Let us know how it goes, and remember, without pictures, it never happened.
