Unread 05-24-24, 01:27 PM
JFlog JFlog is offline
JFlog is on a distinguished road
IO 360 D Accessory case needed
Hi Folks
I could use some assistance pointing me in right direction. I’m fairly new to using this site. I have Cessna 337, N108CC, sn 337-0202. IO 360 D motor in back chewed up oil pump gears and accessory housing. My engine shop is fairly new to this model of engine apparently. What they have found so far is that there were 3 versions of the accessory housing and oil pump gears. It seems I have the oldest version and finding a new accessory housing and gears is so far challenging. One option the engine shop outlined is a newer accessory housing/case, but they said most have a place to put and oil filter adaption vs the screen mine uses. However, I’m told the engine will not fit into the engine bay with a filter adaptation on it. We can’t for some reason get the accessory case serial numbers but do have them for the different gears. Any suggestions? Thanks
