Unread 12-13-24, 09:35 AM
Frank Benvin's Avatar
Maybe air in the system . After the repair did you cycle the gear several times Open the doors on the ground and start up and close the with gear handle Also after these close hold gear handle down for a few seconds to cycle pump then try and see if you can add more fluid. I did this for the first few flights after we rebuilt actuators and replaced hoses
1967 337B
