Hi there
I had an over voltage issue a couple of years back, with some great guidance, hours were spent testing every circuit breaker, all terminal connections and switch’s.
Although all switches, circuit breakers and terminal connectors were replaced during the restoration process some 5 years earlier.
What I found was a circuit breaker that was creating resistance, leads from the alternators to the charging control were also creating resistance, including some terminal connectors.
In effect we found 1350 ohms of resistance, once corrected the issue went away. Post the correction, I also decided to change the regulators and the over voltage relay.
Dave S
1974G
VH-DCS
