Unread 08-18-25, 10:00 AM
Burt Burt is offline
Gear Handle
There is a solenoid behind the lower panel adjacent to the gear handle which prevents the handle from being raised when the aircraft is on the ground. That solenoid is energized by a squat switch on the nose gear. So you either have a bad solenoid, or bad squat switch, or an open circuit in the wiring.
Burt
N337Y
337A
