Unread 09-07-25, 07:44 PM
Randy
Not exactly sure how the electric hydraulic squat switch works in the system but what you describe is this how it protects the gear retraction on the ground? The doors will open?
As you probably know with the gear driven pump on the earlier models the gear handle is locked out to avoid any possible gear retraction on the ground or weight on wheels.
Just curious
