Unread 11-22-25, 06:49 PM
Joes Joes is offline
I have used a levered oil can forever, such as an ARES 55010 – 16oz Red Lever Style Oiler Can. This is just an example of the type of oil can. I only get one use from the cheap plastic hose; the petroleum makes the soft plastic rigid. If there was a leak I would pull a vacuum from the caliper using a snap-on brake vacuum; nothing wrong with the fluid, and it can be reused.
