Unread 02-13-03, 05:15 PM
bede1@msn.com bede1@msn.com is offline
bede1@msn.com is an unknown quantity at this point
Wink pulsing lights
Kevin,
Guess you were right on the beacon. Found that the strobe bulb was bad (didn't flash) and the electronic flash module was still pulsing. Replaced the strobe bulb and the pulsing panel lights went away. Thanks for the clue. Also found that the power pack was down below the add mark on oil. Filled it up to the proper level, flew plane and cycled gear a few times. After landing left master on in hanger and even after 30 minutes I did not hear the pump cycle once. Did find a small leak around the pressure switch. Had that repaired. Will watch for any further loss in fluid. Again thanks for the help.
Bob
