Unread 04-28-03, 05:21 PM
Bob Cook Bob Cook is offline
re single engine altitude
I would assume;
1) 75% power or greater. 31/2800 would be minimum.
2) I would consider trying full power to see what would happen.
3) You should be able to get 37" at test altitude otherwise your turbos or engine is not putting out.
Believe the book figure is based on full gross or 4800 lbs, therefore there is something wrong.
I have operated single engine at 13k ft in colorado without overstressing the engine. Think it was 31" and 2700 rpm.
bob
