re lean
I didn't say lean ROP, I said "lean ROP or LOP to >60 ROP if necessary... depending on power".
Your POH shows max cruise settings and they are at PEAK EGT if you compare the fuel flows with the published TCM figures in the 360 manual.
"Depending on power" is the key phrase.
I do not advocate running LOP....... that is up to the skill, and knowlege of the pilot. Some pilots run LOP above the shoulders......
bob
