re converter
Stackj
Unit is a SYNCRON RT10A NLS. This model is 10 Amps continuous. Input voltage 24-30 volts output is 13.5 volts.
Screw terminal block in and out. Fully protected with reverse polarity protection.
size is about 6X8X6 inches. Aluminum heat sink included.
should be able to pick it up from Amateur radio supply store (AES) or equiv.
fyi
bob
