Peyton,
I too had water in the rear engine resulting from the install of an oil/vapor seperator. Dale is exactly correct... it is condensation from the seperator which in my case, was freezing in winter and also presurrizing the case. I ended up removing the seperator and the engine went back to breathing normally. Dale's suggestions (insulation) are probably better.
