jacks
John
There are no need for boom jacks when doing an undercarriage swing. There is a nose jack point (like the wing) just behind the front nose gear. You will need to support the aircraft at that point with some form of adjustable support or jack. You will probably need to put an some sort of support (safety) underneath the rear boom as a precaution. Check the manual when you get it.
GMAS may have some other suggestions.
bob
