Just remember, for purposes of this thread, that all of the models aren't the same, beyond just the main/aux. and all-in-one difference.
My model will draw fuel just fine with the fuel pumps even if you run a tank dry. Doesn't make any diff. if you run it dry or switch when things start sputtering except for the extra seconds to start if you let the line run dry before turning the switches.
And far as I can tell there is no such thing in my particular model that requires the mains to be run down an hour before you can switch to the aux. and not lose fuel overboard.
So they're not all the same.
