Contact Cessna in Wichita or Yingling...
My, my, my... What to do without a Cessna Parts and Service Manual. You'll need those first from Cessna... THESE ARE MUST HAVE ITEMS! Then you'll have the views, parts lists, part numbers, etc. to properly locate the specific items needed for your airplane, which any of the Cessna dealers can supply... or at least if you have the Parts Manual you'll have the item number which will enable you to cross reference to Aircraft Spruce or other sources... otherwise you might as well be flying IFR without a DG & AH.
Yingling Aircraft is located in Wichita and used to be one of Cessna's largest dealers... as they are located on Mid-Continent Airport, not very far from Cessna's parts distribution center. They can probably assist, but FIRST THINGS FIRST. Get the manuals to you have a guide.
SkyKing
