all the synolids (?) are basically automotice, i replace all four of mine at around 30 bucks each . sometime as wiring gets old it get brittle, so what you have is it works then it doesn't and th same with squat and down and locked or up and locked. i have had my a/c up on jacks many time and it always works (even with putting a load on the cycle) the lasttime it was a squat that was gong bad and would work then not. one time few 200 miles with the gear 1/2 retracted (the bose wheel makes a great front rudder and really tires out the foot). i shorted out the squat switch wires and the gear worked perfect, replace the sw and all is fine. the other time it was a broken wire at the up lock switch which indicated the gear was not down and locked, this may not help at it is a 73p; however it is realative and it usally comes down to broken wires or switches/
