Unread 04-21-02, 02:11 AM
SkyKing SkyKing is offline
Jim,
I'm presuming you have a Cessna parts book for your plane. As mine is pressurized and a later year model, there might be some slight differences, but I'll try to direct you to the right place so you can identify the part I'm tryng to direct you to, i.e. the contoured cover I mentioned above.
If you'll look for Figure 3, or perhaps another number on yours, but look for "Complete Wing Assembly" and Item #46 and #28. #46 is the contoured cover on the lower half of the boom, located about half way between the strut attachment point and the aft edge of the wing... this contoured cover is probably about 12 to 14 inches in length... under this cover is an access door, Item #28 and there are 28-screws to be removed.
As you look at Figure 3, the area you're looking for is in the middle of the boom area shown.
Let me know if this helps... otherwise, you can e-mail me direct.
SkyKing
