general turbo thoughts
i've run turbo skymasters for 20 years. living in colorado the turbos get used! the wastegate controllers tend to coke up when the shafts wear. with 3000 hours i would bet the shats are worn. you can use a copper based lubricant periodically or have the wastegate overhauled($s). i also have had problems with the turbo controller, it seems a lot of shops don't know how to correctly overhaul them. eventually i found someone at firewall forward in ft collins, co that knows what they are doing. what i have noticed over the years is that shops in the mountain areas know a lot about turbos and oxygen systems because a lot of aircraft have them. sea level shops just haven't seen that many. as far as induction leaks, i had a rubber coupler come completely loose and still got near full boost at 7000 feet. the turbos are a bit overdesigned.
