Unread 04-16-04, 07:31 PM
alternator
For what its worth! My bird is a 1975 P337G Riley. Just replaced the alternator driver coupling on rear engine. It was not in use for about five weeks. Started the rear engine and still had alternator light out on. Checked all wire hook ups to the alternator. All okay. Checked Voltage reg. and it tested okay. Checked fuse on firewall. Looked good. I took the fuse out and it was okay however had slight buildup of dirt and crud. Cleaned both ends of the fuse with wire brush and cleaned the saddle the fuse sits in. Yep! Everything works fine now. Message, don't over look the small things.
Jerry
N34EC
