Quick drain on the front engine is a no no.
For the reasons you have discovered. It protrudes into the wheel well, and the wheel hits it. If it didn't open the drain, it would put a hole in the tire.
Both are bad.
The answer to the rest of the question is no. There is no way to put a quick drain on the front engine of a skymaster without causing problems.
