Unread 07-10-04, 02:58 AM
if a coupling fails the carging systems turns to garbage. fooled around with mine for over a year. did everything and it turned out that the coupling would work on the low end and as a load was placed on it would taper of on voltage and the alt lits would keep blinking unti they finally stayed on. (73p) you can stick your finger into the alt and see it turns. if so maybe that is where the problems lies.
