Unread 06-20-02, 07:51 AM
Bob Cook Bob Cook is offline
riley AC
Ron
I know the system inside out. If your mechanic calls me i can give him directions.
I am sure you have a freon leak /r 134a. Guage ports are on back wall. any AC person can do the test. there is a low pressure cutout also high pressure cut out as well. The leak is probably the U joint on the high side at the compressor or a lose bulkhead connector between the evaporator and the rear AC bulkhead.
The wiring is really simple and elec troubleshooting is simple as well. I have the wiring diagrams.
I had to get system going myself. Once fixed it will hold.. Basically it is an automobile system.
Re baffling, you do need to try and sort out the leaks.
Bob
