Unread 08-16-04, 11:05 PM
travis's Avatar
travis travis is offline
Hi,
I just had a version of this problem! The gear doors would not close after the gear retracted.
I found that the answer is not in the sequencing valve but in the door solenoid switch. I think that the part was $6 (cheep anyway)
If the doors close one way and not the other, but you get a positive lock light (up and down) then the problem is either the wire or the switch. It is located on the left side of the power pack and can be herd when the handle is moved through the neutral position (do not move the handle through the neutral position with either of the engines running or with electrically operated gear).
_travis
