Unread 12-02-04, 02:35 AM
You're probably right, but a little more research is probably required.
On your model ('76 P337), the static ports are in the left strut. There are two small holes facing forward. I believe the lower is the drain (I could be wrong). The question is if the pitot hole is blocked, and the drain tube open, will it read 0 on the airspeed? Normally I'd assume this to be true, but since the drain hole faces forward, I don't know what to expect in this situation.
