I'm not an expert, and others may want to add to this, but I understand that the regulator(s) balance the load between the alternators. The service manual (your mechanic has one for your aircraft, right?) has clear instructions on adjusting the system for proper balancing. I don't think that you are at risk of damaging anything running a moderately unbalanced system, but it would be a good idea to do the adjustment soon.
One of the most knowledgeable contributors to this Message Board in this technical area is not too far from you, Pete Somers in Yorkshire, UK.
