Thread: Syncrophaser
Unread 03-05-05, 05:20 AM
Hi Kyle
The main problem we had with these is the pickup on the prop governors.
They are either set incorrectly or they go open cicuit.
The pickups should be set as-per the manual, which i think you screw them in until it stops then unscrew a quarter on a turn, but check with the manual.
Check that both pickups read thru with a meter.
Have a look at the motor and the microswtches, If i remember rightly the motor should be at one end of it,s travel when switched off, so that you get full prop control movement.
If the system is a SP105 the manual is quite good, and it shows you how to build a test box.
Pete
