Unread 03-06-05, 01:20 AM
New TBO Poll (Turbo and P Models)
POLL INSTRUCTIONS
If you have ever had a Skymaster Engine overhauled/replaced/remanufactured, please select the number of hours on the engine at that time.
If you have had more than one engine overhauled/replaced/remanufactured, please answer the poll based on the engine MOST RECENTLY done. If two were done at the same time, flip a coin (literally).
NOTE: This poll is for TURBOCHARGED or P-MODEL skymasters only. If you have a normally aspirated model, please use the other poll.
If you have suggestions on how to improve this poll, or ideas on other topics that you would like to see incorporated into a more formal survey, please comment in the thread "Ideas for TBO Survey."
OPTIONAL DATA
If you have time to comment more fully on your TBO experience, please attach a message to this thread and answer the following questions:
1. If you have had this experience with more than one engine, list the times for the other engines.
2. List the age(s) in years for the engines at overhaul.
3. WHY did you decide to overhaul your engine(s) at that time (if there was a mechanical problem, please be specific).
4. Did you ever do any major repairs to the engine(s) before overhaul (eg: top overhaul, etc.) If so, please list the type of repair and the engine hours at which it was done.
5. Any other comments you care to make concerning your TBO experience.
I will perform a more thorough spreadsheet analysis on the supplemental data and post it for everyone.
Thanks for your participation!
