Unread 03-30-05, 10:51 PM
djarrett djarrett is offline
djarrett is an unknown quantity at this point
Talking
what we found. left main gear squatswitch was loose and sometimes gave indication or flickered. switch was tightened and properly positioned. the hyd pump was working properly and turning off when it reached 1500 psi and then a short cycle and turned off. When your head was lowered to attempt to hear the pump the cooling fan sounded different when you head was lower than the dash. The cost of figuring out the bugs and time and no parts, was a little over $300. the shop ate the cost for the cleaning of the cockpit and scrubing the carpet.
Thanks again
Dave Jarrett
