Unread 04-01-05, 03:45 PM
Dale Campbell's Avatar
Electrical Power Failure
HI GUY AND OTHERS,
I just ran up to hanger to check plane on lunch hour. Guy, you are right the red light is the over voltage light. The one that is now staying on is the DIS amber light. I started both engines on ramp and did some testing at 1500 rpm. I tried first one and then the other alternator switch on and both give the same output on ammeter. I turned everything off while keeping engines at 1500rpm and ammeter shows a good charge but the DIS light stays on all the time. I will go back saturday and pull cowling and check all diodes and solinoids with a VOM meter. I have found many problems in the past myself. Dale
